2011-02-24
05:28 PM
2023-05-25
06:04 PM
Rubia Torres
2011-02-24 06:30 PM
Files created on a trial version are encoded, and can only be opened with the copy of ArchiCAD that had created them. If you uninstall this copy of ArchiCAD, you will not be able to open the files anymore, not even if you install ArchiCAD again with the same serial number. If you already uninstalled ArchiCAD trial, the only way to open the files created with it is to try to recover the uninstalled copy of ArchiCAD
2022-01-21 03:07 PM
Dear, Eduardo. I used a trial version to create a project and it has expired. I've tried to download another version using a new profile and a new Archicad installation on the exactly same machine. Still doesn't work. Have I lost the files for good?? No other way to access it? Even if I bought the licence? Thanks
2022-01-21 03:42 PM
It will not work. You should get in contact with your reseller and see if he can do something about it.
