Manish
Unable to change railing materials
Hello everyone,
Need help!!
Archicad 23:
I am unable to change my railing materials. When I am creating a new railing ti shows a single material, which is not editable. I tried a lot but had no success. Even if I am importing or copying a railing from another project, that also has one single material.
Photograph attached.
Regards, Manish
1 Solution
Erik Bjornhage
Check your MVO settings and make sure you don't have simplified with an Override Material on.
Erik Bjornhage : SwedishChef, INSIKT Digital Sapiens, Gothenburg, Sweden - Architect : Digital Development : Graphisoft Cert. BIM-Manager - Eriks LinkedIn : INSIKT
ThinkPad P1 G7; Ultra9 185H; 64 GB; RTX 4070 [8GB] : AC12 - future
Go to post
4 Replies 4
vistasp
Mentor
Do you have a graphic override active?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Erik Bjornhage
Manish
Thanks Vistasp, found the solution.
Problem was in MVO setting.
Regards
Manish
Thanks, Yes there was there problem.
Regards
