Unable to change railing materials
Manish
Hello everyone,
Need help!!
Archicad 23:
I am unable to change my railing materials. When I am creating a new railing ti shows a single material, which is not editable. I tried a lot but had no success. Even if I am importing or copying a railing from another project, that also has one single material.
Photograph attached.
Regards, Manish
undefined
Erik Bjornhage
Check your MVO settings and make sure you don't have simplified with an Override Material on.
Erik Bjornhage : SwedishChef, ETTELVA Arkitekter, Gothenburg, Sweden
Architect : Digital Development : Graphisoft Cert. BIM-Manager
ETTELVA Arkitekter : Eriks LinkedIn
DELL Precision 5570; i7-12700H; 64 GB; RTX A2000 [8GB] : AC12 - future
4 REPLIES 4
vistasp
Do you have a graphic override active?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Erik Bjornhage
Thanks Vistasp, found the solution.
Problem was in MVO setting.
Regards
Thanks, Yes there was there problem.
Regards
