‎2022-01-20 03:36 PM
Hello everyone,
Need help!!
Archicad 23:
I am unable to change my railing materials. When I am creating a new railing ti shows a single material, which is not editable. I tried a lot but had no success. Even if I am importing or copying a railing from another project, that also has one single material.
Photograph attached.
Regards, Manish
Solved! Go to Solution.
‎2022-01-20 07:47 PM
Check your MVO settings and make sure you don't have simplified with an Override Material on.
‎2022-01-20 04:31 PM
Do you have a graphic override active?
‎2022-01-21 09:20 AM
Thanks Vistasp, found the solution.
Problem was in MVO setting.
Regards
Thanks, Yes there was there problem.
Regards
