Opening tool in different skins
Rve
Is there a way to create ONE opening in a Wall (not composites, but all separate skins) and where the size of the openings in every skin is different (or better parametric)?
Normally i create my own Windows and they are placed in the Outer skin. They don’t break into the other skins because all my skins are created individual (no composite), I’d like to find a simpele way to create ONE opening in the insulation and construction skin that cuts both but has different sizes. Can someone help me? Perhaps someone already has created a tool or object themselve
narcis
You can create one or more openings in one or more material using "Opening" tool.
AC26 3001 UKI (from AC13)
HP ZBook Power 15.6" i7-13700H @ 2.4Ghz, 32GB RAM, NVIDIA RTX 2000 Ada Gen, 1TB SSD, Windows 11 Pro
MacBook Pro M1 Max 14.2", 10-core CPU, 64GB RAM, 32-core GPU, 1TB SSD, MacOS Ventura 13.6.2
Self-guided, shape it until it shifts.
The OP is wanting the size of the opening to stagger between the different walls...
