Rve
Opening tool in different skins
Is there a way to create ONE opening in a Wall (not composites, but all separate skins) and where the size of the openings in every skin is different (or better parametric)?
Normally i create my own Windows and they are placed in the Outer skin. They don’t break into the other skins because all my skins are created individual (no composite), I’d like to find a simpele way to create ONE opening in the insulation and construction skin that cuts both but has different sizes. Can someone help me? Perhaps someone already has created a tool or object themselve
2 Replies 2
narcis
You can create one or more openings in one or more material using "Opening" tool.
AC28 28.4.0 (7006) UKI FULL (from AC13)
HP ZBook X G1i 16" Intel Core Ultra 7 255H, 32GB RAM, NVIDIA RTX PRO 1000 Blackwell 8GB, 1TB SSD, Windows 11 Pro (Build 26300)
MacBook Pro M1 Max 14.2", 10-core CPU, 64GB RAM, 32-core GPU, 1TB SSD, MacOS Ventura 13.6.2
Self-guided, shape it until it shifts.
Guru
The OP is wanting the size of the opening to stagger between the different walls...
