MSDC
Opening tool lines in section/3D
Is there a way to hide these lines in 3D which are created by an opening in a slab?
1 Solution
Not the answer you probably want.
Don't use the opening tool, just cut a hole in the slab.
Go to post
3 Replies 3
runxel
Sadly, no. 😢
I've been begging for this for years now.
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
MSDC
Yep that's what I've always done.. thought I'd give a new(ish) tool a chance 😄
