Opening wrap
Hello, how can I make this opening to show correctly, see the gypsum in the bottom is not wrapping correctly, I made it right in the other side, and it should work right in this side, but because is in a corner is not working right, if I move it up a little bit it will work, but not here.
I can't find how to make it work right.
2 Replies 2
I would try to stop the Wall of the opening just before the perpendicular Wall so they do not join.
It can be as small as 0.1 mm so it doesn't even show on the final output, but the middle skin of the composite will not turn.
I think I'll do that in the mean time, but if is that I can't find it, we are missing a option for this, so this will work right.
