2016-06-13 02:13 PM - last edited on 2023-05-24 12:42 PM by Rubia Torres
2016-06-13 03:34 PM
2016-06-14 09:28 AM
Erwin wrote:thanks!
Mass model it with Morph tool until you like what you have. Walls can be pitched, but you can also draw it with roofs, shell, curtainwall tool etc
But I would start with massmodelling with morph tool for the preliminary desing. You can snap to the morph in 3d, to draw roofs/shells/curtain wall on top of the morph shape.
Morph will also allow you to do quantity take off for any stories you define and you can set it to project the proper cut for the floorplans, start drafting zones on top of that to figure out the program of spaces etc etc
Check out some of the recent youtube tutorialshttps://www.youtube.com/playlist?list=PLnXY6vLUwlWWJawLurhjmdS9-W1oaUSnQ
2016-06-14 10:12 AM
2016-06-14 09:28 PM
Erwin wrote:blender but i can export in (almost) every format i want to
Depends on what program you used, but sketchup, for example, can be imported as object, which in turn can be turned into a morph.
2016-06-16 11:43 AM
2016-06-16 12:48 PM
2016-06-17 03:01 PM
Erwin wrote:yes, seen a lot of them, but morph tool would be way more useful if you could easily swap morph faces with typical him elects, i mean, i can model without any problem my shapes, but once i try to put "thickness and materials" to the various faces i need anyway to manually input angles etc. am i missing something?
It doesn't have to be a wall, you can also use a roof, if the shape is too irregular. Or just give the morph more detail. Have you seen the morph tool videos? They are making all kinds of free form stuff, even TIE fighter.
