We value your input!
PM 9 - Title blocks not present in DWG
Hi everyone
I'm trying to save sheets from PM 9 to DWGs (publish menu) but when I open those DWGs with Autocad the title blocks aren't present...
Does anybody know a way to get things right ?
Thanks in advance.
4 REPLIES 4
I cant help you but i can tell you that this has happened to me as well. You are not alone....
Hello Carrère
Which version of Plotmaker did you use.
Your problem had ever seen in this topics http://archicad-talk.graphisoft.com/viewtopic.php?t=2942.
Il you try to read your dwg with your AC or PM the problem may be the next http://archicad-talk.graphisoft.com/viewtopic.php?t=4787, try with AutoCAd or a dwg viewer.
Hope this helps
Djordje
carrere wrote:
Hi everyone
Thanks in advance.
They are in PaperSpace.
Post a screenshot of your Translator settings.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
I upgraded my Archicad with the hot-fix2 and it made it !
Now everything works fine although that bug was not listed...
Thanks everyone
