PROBLEMS WITH COMPOSITES
Hi!
I'm working on Archicad 12 and currently I started using customized composites for a project that has several types of walls.
I have therefore made several types of composites for this purpose and everything was working OK.
However after a few work sessions I tried to create a new composite and the composite dialog box started to have a strange behavior that I haven't watched before: the "edit selected item" folder title on the box is showing light Grey and when I try to open it it opens and immediately closes )rolls down and rolls right back up again) not allowing me to change any of the parameters.
I have tried to exit and re-enter the Archicad session and its still having the same behavior.
Could you please tell me what may be causing this situation and what can be done to correct it?
At the moment I'm using 2782 INT FULL FOR TEAMWORK version of Archicad 12 for Windows platform.
Thanks!
1 REPLY 1
Maybe you have to sign into the project with Exclusive Access.
You can create new attributes but can modify existing ones only when signed in with Exclusive Access.
TW2, available from AC13 is fully flexible in this respect.
