Marky Lucky
Paneled wall display
Good evening, I would like to create a continuous surface made up of several panels juxtaposed together using the cube element. I continue to visualize their division in elevation and in section while they are perfectly juxtaposed. Do you have a solution?
10 Replies 10
Lingwisyer
Guru
Always forget that Element Origin is only valid for the rotation not the origin... My bad...
