2019-11-21
		03:39 PM
		2023-05-09
		04:19 PM
			Rubia Torres
2019-11-21 04:20 PM
2019-11-22 07:40 AM
2019-11-22 01:23 PM
2019-11-23 08:21 AM
4hotshoes wrote:When you change the value of Ledge Ht to a negative value it should be higher than the rest of the wall. If you want the values to be reversed, so when the ledge is taller it is positive, when you’ll need to change the geometry in the profile editor so that ledge it above the wall.
I would like the "Ledge Ht" to be changeable higher or lower than the Nominal Height. I am unable to do that.
2019-11-23 11:07 AM
2019-11-26 03:22 AM
DGSketcher wrote:Hotspots placed into the Profile will "generally" move with Parametric Edges, and that hotspot is what Dimensions attach to - as they have unique identifiers so they can keep attached to the dimension even when the shape changes. Or do you want to move a single node and not an edge?
@JamesB: Is there a way to invoke parametric nodes (hot spots) within the profile as some shapes do require more dimensioning than just the bounding box and don't justify being exploded into a detail?
2019-11-26 07:17 AM
2019-11-26 08:25 AM
2019-11-26 11:29 AM
