2024-11-07 05:08 AM - last edited on 2024-11-11 04:10 AM by Karl Ottenstein
I just wanted to post this out here maybe some users can give ideas or tips or techniques to do this much simpler and easier.
The image below is done using a beam which I have manually adjusted the lengths in a section view to make it more random.
My question is there an easy way to do this? like Param-O and how difficult or easy it would be? Thanks for the help in advance!
Operating system used: Windows 10 Pro 22H2
Solved! Go to Solution.
2024-11-08 11:00 AM
You can achieve this in Param-o, but GDL offers more control over the process. Here’s a setup in Param-o where the bars are drawn through, and the seams/joints are cut out. However, a drawback in Param-o is that you don’t have control over the seams positions between adjacent rows.
To make adjustments easier, I've added just additional hotspots in GDL.
Have fun!
2024-11-08 11:00 AM
Have fun!
2024-11-11 03:48 AM
@cuba Appreciate your help with this, and thanks for sharing the gsm file. For sure it will help a lot of other users that are looking into this kind of objects. 😎
