SOLVED!
Parapet level of windows
Attila
Hi everyone,
My question is, if I create a reference level, can the window parapet level be set to this reference level somehow? In the consignment list, it prints the parapet from 0.00, which is not a true height relative to the floor covering.
1 ACCEPTED SOLUTION
Solution
If you mean that you want the Window to be associated with the Reference Level and if the level height is redefined, the Window moves vertically, then the answer is no. Doors/Windows can only be associated with their Story Level, the bottom of the host Wall, or the top of their host Wall.
3 REPLIES 3
Hi @Attila,
Pls take a look at this topic, I think it’s relevant somehow to your issue, hope it helps.
https://community.graphisoft.com/t5/Documentation/hight-dimensioning-tool-with-storeys-to-choose-as-...
AC 28 INT 5200/WIN 11
Solution
Thank you very much. That's what I meant.
Setup info provided by author
