Streamline your workflows and master BIM coordination! Program starts April 28.!
Part of beams missing
Hi people!
I'm having a problem with my beams. Part of them are invisible, and I can't seem to find a way to make them visible again. As you see in the image they have a few lines showing, but most of it is invisible. The ones on the end are behaving most odd, but the other beams tend to show only part of them, depending on what angle I'm looking at them from. Does anyone have ideas about what the problem might be?
Thank you!
(Archicad 19 on a mac)
undefined
Stephen Dolbee
Is it possible you have 2 beams occupying the same space? Try deleting one and see.
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
It is also possible that another element with a Building Material with a higher Intersection Priority (such as a Wall or Slab) intersects with the Beam and removes that Beam (cuts it because of the higher Intersection Priority).
