2010-02-24 12:10 AM - last edited on 2023-05-26 12:20 PM by Rubia Torres
2010-02-24 01:04 PM
Peter wrote:You will have to use the Filter Elements in 3D Dialog to hide the Doors/Windows. Then you may want to save it as a View for later reuse.
I haven't played with this feature much before over the past two AC releases, but I have a few questions that I can't find the answer to in the manuals.
1 - When you switch to 'core only' are the doors and windows meant to stay turned on in the 3d window? I have a video from the AC12 release appearing to show the D+W turning completely off, which I guess would be the obvious behaviour, but unfortunately in AC13 my D+W stay visible. Am I missing a trick?
2 - How do use the Partial Structure settings for ceilings or floor finishes if you have separately modelled the plasterboard/floor finish from the structure? You can't have a single skin of plasterboard assigned as a finish in a composite. It needs to have a minimum of one skin defined as a 'core'. In a complex profile you don't have this limitation - you don't need to have any skins specified as a core, so why is there this difference?That's a tricky one. I would say you should place those one-skin elements on a separate layer.
3 - Why doesn't the Partial Structure effect apply automatically between any viewpoints opened from the Project map like all other settings do e.g. layer combinations, pen settings, scale etc? It seems to be individually switched for each viewpoint. For consistency shouldn't it behave like any other setting?Yes, this is how it works. The Partial Structure Display is Viewpoint-specific so it remembers its setting in 3D, Floor Plan, Sections etc. even if you are not using a View to go there. I am sure it is so by design.
Thanks in advance!
2010-02-24 06:26 PM
2010-02-24 07:10 PM
Peter wrote:As I think you pointed out earlier, you can do this with profiled walls. Slightly inconvenient but functionally equivalent. Just make sure the source profile is not taller than the shortest wall you need to make.
Just having the ability to assign a single skin composite as a finish would certainly help matters especially if you have to use discrete pieces of single skin wall and slab to fill in various gaps in the modelling.
2010-02-24 08:33 PM
2010-02-25 06:32 PM
Peter wrote:Strange, I would have dared to say this setting affected S/E, but apparently it doesn't.
Out of interest, how would you turn off the doors and windows in sections and elevations - the 'Filter Elements in 3d' settings have no effect in these views. I presume the main purpose of this setting is for displaying information for the structural engineers, but why would they need to see the door and window frames? Surely 'core only' should only display just the core elements and nothing else?
2010-02-25 06:33 PM
Peter wrote:Well, I am not completely happy with this either because this can result in double dimensioning.
I also find it disconcerting that dimensions are associated with the partial structure setting that was activated when the dimension was placed, and acts like a secondary layer system - even if the object being dimensioned has no partial structure settings like a simple uniform fill slab. I'm not sure I like this behaviour. Would it make more sense if dimensions were able to tell whether the associated geometry was still visible or not, and then decide if they should display?
2010-03-04 02:52 PM
Peter wrote:OK, I asked the developers at GS about this.
2010-06-02 04:25 PM
2010-06-02 06:13 PM
