Pen settings
I changed all the pen settings manually to several objects (windows/doors/slabs/stairs) in project map, realizing I should have kept them original in order to set the graphic parameters in the pen set to apply them in the views.
Does anyone know how I can reset the pen weight and colors to these objects that I edited, so they respond to the changes I make in the pen sets?
Thanks a lot!
Regards, Bjarte Stav
1 Reply 1
You can start a new project with default settings.
In that file the GDL Objects should appear with their default settings when placed.
Then copy-paste one such instance from that file to your other file where you modified the settings.
Then use parameter transfer (ALT-Click + CTRL-ALT-Click) to inject the parameters of the copy-pasted GDL Objects to the modified objects.
