Perspective views....
Looking for a little help... When trying to develop a perspective rendering I am having problems going from plan to the actual perspective I want to see. From plan, when I set the angle I want to look at and then go to my 3D perspective window, the same angle always shows up. From here I can then set the correct angle, but not until the perspective that I didnt want to see finishes loading. This can be time consuming and literally doubles the time it should take. Is this clear? I'd appreciate any suggestions...
Mike
ArchiCAD 8.1
MAC
mike, try using the camera and put them where ever you want to look and then you can switch between them without stressing and waiting.
Djordje
... and, of course, save the 3D views. All the settings, including layer combinations, display options, rendering engine settings, and so on, are preserved. So switching from one view to another is easy - double click. Depends on the view how long it will take to regenerate.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
