Pivot Door in Curtain Wall
I am using a curtain wall , and trying to assign a pivot door to some panels, it doesn't look like an option, any thoughts?
Thanks in advance.
Whether you can use a pivot door depends on having one in the library. If there isn't one it can be created as a library part either by scripting or modeling it. If you make one the key thing it to set the subtype to a curtain wall panel.
Yeah.. unfortunatly I am not that good with scripting . anyhow thanx Matthew.
