Placing a corner window in a Profiled Wall
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-02-16
09:16 PM
‎2023-05-26
03:00 PM
Rubia Torres
‎2007-02-16
09:16 PM
We keep trying. The corner window will place successfully in a simple or a composite wall. If we place it in a Profiled wall, Archicad only places one window, like it was a normal window.
Has anyone else seen this? Know any workarounds?
Tom Waltz
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-02-20 11:40 AM
‎2007-02-20
11:40 AM
Tom,
Since corner windows can not handle complex geometries (when they are in a slanted position), corner window functionality is disabled for slanted and profiled walls. Therefore the corner windows will not "try" to behave like a corner window in a profiled wall, not even when the wall is actually a straight wall with footing or cornice. I understand that in these situations when the geometry of the profiled wall would allow the window to work normally, we should enable corner window functionality, but I am not sure if and how can we "detect" those situations.
Gergely Kmethy
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-01-13 10:46 PM
‎2009-01-13
10:46 PM
Along with this same topic, I have been working with the corner window tool and am having trouble with putting a corner window into a composite wall (that is not a complex profile) and then intersecting that wall with a complex profile. I keep getting the warning below. Has anyone seen this before?
I'm I doing something wrong. According to all the posts that I have seen, placing a corner window into a composite should not be an issue. Also, when I try to do this when I am intersecting a composite with another composite wall I get the same warning, so I doubt that the complex profile is my problem. I have not gotten around to assigning the composites to the complex profile, could that be a reason?
Thanks,
Rachel
Thanks,
Rachel
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-01-14 10:33 AM
‎2009-01-14
10:33 AM
Tom : In those situations I normally put an empty opening in end of the walls that cut a hole. Then I put a window in that hole and create the corner manually or build the corner situation as a standalone GDL object that I put in the hole I created above.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-01-14 03:28 PM
‎2009-01-14
03:28 PM
Ok, thanks, that's what I figured I would have to do... Have you ever seen this error prompt before? Or is it basically just telling me that this command cannot work with my wall geometries?
