‎2005-12-17 02:50 PM
‎2005-12-18 12:28 AM
‎2005-12-18 01:21 AM
Aussie wrote:What are the "cetain" did you mean "certain"
( some other things too such as cetain fills)
‎2005-12-18 03:03 AM
‎2005-12-18 03:59 AM
miker wrote:You should save a view for every scale that you will or are working with.
And what is going to happens if ,as you progress in your plan,you find out that is necessary to change the scale of the plan.
And for the text you can set it to "Scale Sensitive" but what are the other object you said?
