2014-05-17
		02:42 AM
		2023-05-24
		08:59 AM
			Rubia Torres
2014-05-17 02:58 AM
2014-05-17 02:51 PM
2014-05-17 07:06 PM
David wrote:
Jonathan:
I have been able to keep the Wall Reference Lines where I want them, so I think you should look at some other options.
In your first screen shot (2 by 6 walls firecode gyp to stucco.jpg), do all the wall layers have the same Layer Intersection Group Number? That was the only way I could reproduce your image.
Also use the Walls' Junction Order (Help file: Virtual Building > Construction Elements > Element Intersections > Specific Element Intersections and Junctions) to help change how 3 walls interact at a junction.
2014-05-19 01:34 PM
Jonathan wrote:They should be the same, making them different was the only way I could find to get your posted result.
Yes, my interior and exterior walls have the same Layer Intersection Group Number. Do they need to be different numbers?
Jonathan wrote:In the search box try "Specific Element Intersections and Junctions", it should take to to a link for this page:Specific Element Intersections and Junctions.
After several attempts to follow the string:
Giving up for now - The help file takes me to the jpg below and if I search virtual building it takes me to earlier versions of archicad info for pre BIM explorer stuff.
2014-05-19 06:28 PM
David wrote:Jonathan wrote:They should be the same, making them different was the only way I could find to get your posted result.
