2005-03-29 11:13 PM - last edited on 2023-05-25 06:21 PM by Rubia Torres
2005-03-30 12:01 AM
2005-03-30 12:39 AM
2005-03-30 03:56 AM
Peter wrote:The problem with this method is one have to do some tweakings to make it looks right on plan. Thus I would rather save the profile as Window and insert into the wall.
JF,
In AC 8.1 and in AC 9, you can use Profiler to make
a shape with the stepped shoulder and chamfer with
an arch head.
Use the object in a SEO with the wall as target.
Peter Devlin
2005-03-30 04:56 AM
2005-03-30 04:14 PM
Peter wrote:We can create a slab with contour matching the path of the splay profile and name the slab's ID "wallhole". Then save the slab as gdl obj..............form there just copy the Wallhole script and paste it to the Splay window.
LiHigh,
With your method, how do you get the hole in the wall
to have a shoulder and a splay ?
Peter Devlin
2005-03-30 07:21 PM
