Plot Maker 9
Is there an easy way of changing Master Drawing from sheet 3X2 to 17x11
Basically I have made new master with a sheet 17X11 and imported drawing from Master 3x2 and the option strertch is not available
Please Help
Thanks
21 Replies 21
Ben Odonnell
Link,
you really have become the forum celeb
Good work mate.
Cheers.
Benny
Ben O'Donnell
Link
Ben said:
What if you save out a PMK and then edit, copy & paste from the PMK.
Would that work instead of having to go back into ArchiCAD?
You still need to resize it mate - how would you do that using this method?
Woody said:
Hey, Link; nice article in the February issue of "Envisions"
http://www.graphisoft.com/community/envisions/2005_02_link.html
Congratulations!
Thanks Woody. I noticed Erika congratulated me in the Events forum. I must thank her too. Dom & I organized that article when I met him at the ArchiCAD University in the UK last September, so it has been a while now! I really enjoyed it though and personally got a good laugh out of it. Dom's a deft editor let me tell you! Seriously, it was a real pleasure, although I love ArchiCAD and all it has given me, so it was always going to be.
Link.
Ben Odonnell
I was just thinking that you could edit directly in the PMK file.
You would then eliminate the problem with the text stuffing up when you copy and paste.
Cheers.
Ben
Ben O'Donnell
Link
Oh - well in my case I am already editing the elements directly on the Master (which is less of a maintenance issue for the CAD Template users later), and we still can't resize in PM, so I am back to square one.
Unless I am completely missing your point mate, which wouldn't be the first time.
Link.
Link wrote:
I usually copy & paste into ArchiCAD and resize there. It's a bit of a pain, because curves and text spak out, but it's still the fastest way to resize IME.
So what am I missing here? Are you editing directly on the Master or are you copying to ArchiCAD and Resizing there?
Unless I'm mistaken (which I have been before on occasion ). If you paste the layout into ArchiCAD and Resize it there, when you repaste it into PlotMaker, the AutoText is no longer AutoText.
I certainly agree that Resize would be a good thing to have in PlotMaker but frankly, considering the number of times one would have to do this if templates were used, I'm not sure I think it would be worth the developers' efforts.
woodster
Link
Yes I am editing directly on the master, but when I am creating a smaller titleblock for a smaller sheet, I am copying into ArchiCAD, resizing there, and pasting back into PlotMaker.
This does play havoc with text. Autotext is lost - although you can simply enter the code in ArchiCAD and it will paste into PM okay.
It also messes with layers, line thickness, arc/circle resolution and of course pasting/placement is never where you want it to be.
This entire process is surely going to get easier!
Link.
So I think it's one of those things that just ain't easy
Woody
Ben Odonnell
Link.
Sorry mate,
I was a little unclear before, what I mean is after you have fixed every thing in ArchiCAD save it out as a PMK, then you won't have the problem with your text, circles etc.
Then once back in PM you can open your PMK, copy & Paste. You have then solved your text, lines and circles problem.
Cheers.
Ben
Ben O'Donnell
Ben Odonnell
Woody
That is an understatement.
Cheers.
Ben
Ben O'Donnell
Link
Ben - that's still a great idea. Notch yourself up another beer.
Link.
