ā2005-02-18 03:45 PM
ā2005-02-21 07:20 PM
ā2005-02-21 07:24 PM
What if you save out a PMK and then edit, copy & paste from the PMK.You still need to resize it mate - how would you do that using this method?
Would that work instead of having to go back into ArchiCAD?
Hey, Link; nice article in the February issue of "Envisions"
http://www.graphisoft.com/community/envisions/2005_02_link.html
Congratulations!
ā2005-02-21 08:00 PM
ā2005-02-21 08:04 PM
ā2005-02-21 08:28 PM
Link wrote:
Oh - well in my case I am already editing the elements directly on the Master (which is less of a maintenance issue for the CAD Template users later), and we still can't resize in PM, so I am back to square one.
Link wrote:
I usually copy & paste into ArchiCAD and resize there. It's a bit of a pain, because curves and text spak out, but it's still the fastest way to resize IME.
ā2005-02-21 08:37 PM
ā2005-02-21 08:40 PM
ā2005-02-21 08:44 PM
Link wrote:Sorry mate,
Yes I am editing directly on the master, but when I am creating a smaller titleblock for a smaller sheet, I am copying into ArchiCAD, resizing there, and pasting back into PlotMaker.
This does play havoc with text. Autotext is lost - although you can simply enter the code in ArchiCAD and it will paste into PM okay.
It also messes with layers, line thickness, arc/circle resolution and of course pasting/placement is never where you want it to be.
This entire process is surely going to get easier!
Link.
ā2005-02-21 08:45 PM
woodster wrote:That is an understatement.
So I think it'sone of those thingsthat just ain't easy ![]()
Woody
ā2005-02-21 08:53 PM
Then once back in PM you can open your PMK, copy & Paste. You have then solved your text, lines and circles problem.Ben - that's still a great idea. Notch yourself up another beer.
