ā2007-12-06
11:03 AM
ā2023-05-26
02:52 PM
Rubia Torres
ā2007-12-06 08:04 PM
ā2007-12-06 08:10 PM
Matthew wrote:or click on its tab in Window's Task bar?
Have you tried ctrl+tab to cycle the active window?
ā2007-12-07 07:28 AM
ā2007-12-07 07:37 AM
TurboGlider wrote:Can you minimise or move what is in front of the "working with" window?
Hi!
Never thought about this before, but now I got this problem more often. For example, I use publish and push publishbutton. Then I got a window that tells me what the computer is working with.
But, often when it's finished, this window goes behind publisherwindow, and I can't push [ok] button on "working with" window. Because of that, I can't use my ArchiCad and have to use ctrl+alt+delete. Happens in both AC10 and AC11, anyone else that got this problem?
ā2007-12-07 11:26 AM
Barry wrote:No, it's the Publish window that goes ontop and cover "working with" window. And this window is totally locked out like all the rest in ArchiCad when "working with" window is on.
A screen shot would explain a lot as well if you can show one.
ā2007-12-07 10:05 PM
No, it's the Publish window that goes ontop and cover "working with" window. And this window is totally locked out like all the rest in ArchiCad when "working with" window is on.If I understand you correctly, I have had something similar happen to me when I have zoomed in to a large box of text so far that the borders of the text box are beyond my working window. When I double-click in the text box to edit the text, the text editor window is enormous and covers up everything. And since I can't click outside of the text box as it covers up all of archicad, I'm trapped forever in a frightening world of perpetual text editing! I managed to escape by pressing Ctrl+ENTER. That closes the pop-up window in Archicad, at least for the text editor.
I can walk in the normal Menu but nothing happens when I'm click at something.
ā2007-12-11 07:46 AM
Zolli wrote:Thanks, I'll try that next time it appears. Why didn't I thought about ctrl+enter. Doh, windows+mouse get you dummier, give us keyboard-controlled OS back
You might try that and see if it works. If I recall, this was a way to close a dialog box before mouses became mainstream.
ā2008-01-10 01:40 PM
ā2008-01-11 05:08 AM
TurboGlider wrote:Ctrl + Tab is what cycles you through the various windows
alt+tab doesn't work either (it change software, not windows inside one software)
