Possible bug in publisher?
Hi!
Never thought about this before, but now I got this problem more often. For example, I use publish and push publishbutton. Then I got a window that tells me what the computer is working with.
But, often when it's finished, this window goes behind publisherwindow, and I can't push [ok] button on "working with" window. Because of that, I can't use my ArchiCad and have to use ctrl+alt+delete. Happens in both AC10 and AC11, anyone else that got this problem?
12 Replies 12
vistasp wrote:
TurboGlider wrote:
alt+tab doesn't work either (it change software, not windows inside one software)
Ctrl + Tab is what cycles you through the various windows within AC. If you just want to close the current window, have you tried Ctrl + W ?
Hope this helps.
ah, forget to wrote that ctrl + tab doesn't help.
Isn't there anyone else that have got this problem? Or is it this computer that failure....
vistasp
Could you post a screenshot?
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
I could next time, but it's not that exciting. What you will se is my ArchiCad window and on top of that publisher window, nothing else.
