‎2011-10-06
12:06 AM
‎2023-05-24
01:03 PM
Rubia Torres
‎2011-10-06 04:28 AM
‎2011-10-06 05:39 AM
‎2011-10-06 06:11 AM
craigj wrote:You won't be able to easily dimension the walls though.
Ahh the 10mm plasterboard walls that I would place would be detail elements only, so I thought the nods on the detail elements can be used to pretend the core wall is 90mm instead of 100mm. Doing it this way would disguise the 100mm core wall by hiding 5mm of it each side with half of the plasterboard detail element (with the other half of the detail element being taken up by the existing finish plasterboard on the actual placed wall).
‎2011-10-06 06:48 AM
