2020-04-30
05:06 PM
2023-05-26
02:55 PM
Rubia Torres
Solved! Go to Solution.
2020-04-30 06:18 PM
2020-04-30 06:18 PM
2020-05-01 04:08 AM
2020-05-01 01:57 PM
LaszloNagy wrote:Laszlo’s solution is probably closest to reality as you will always have an air film between any elements unless you are CN milling to the micron level, this also the easiest to model / implement
Or move the middle stud 0.1 mm back so it is not exactly flush with the other two studs.
The move should be so small that no dimension displays it, but ARCHICAD will know they are not flush.
(Of course you might not like this solution, because in CAD we are taught to always model precisely, and I am suggesting you not to model precisely)
2020-05-01 05:37 PM
2020-05-01 06:16 PM
