Problem My Section (Display)
Dear All in Forum
I Have problem in section drawing display screen.
My project total area 13.000 m2 and Finish time deadline 16 Des.2007
My drawings section A to I is normal, section F no full output, and section G no full. and i try rebuilt section F and G continuos and no solution.
My Grafik Card normal and fine and my driver latest Nvidia 163.75 XP X64 Bit.
What Is Bug in AC11?
Please Help Me for solution.
Sorry My English
Thanks,
13 REPLIES 13
Try to move the problematic sections a little bit and see if they rebuild.
Or try to draw new section lines.
Let us see if that helps.
Otherwise delete preference and so on and restart.
Djordje
I have a similar problem with a file saved as 10 from 11.
All is well - after replacing the lib parts of course - except ONE elevation that refuses to open. Even if I delete it and place a new one, the same happens - the hourglass ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks...,
I Say Thanks very much for opinion and all solution my problem.
I try delete one or more line section problem and create new one or more line section and success rebuilt and clear.. no problem, but I'm reinstall system X64 and reinstall AC11 because my system slow begin.
My File project is working AC11 built 1114 and large file 218 MB, is normal and real?..
One question, I'm installed AC11 in OS. Vista Ultimate 64 on Quad Core 2xAMD Opteron 2210 one month ago and turn up (attach my schreen shot) and continous turn up when finish working AC11 and system report (AC11 component has stopped working).
I'm Installed update fix AC11 from original built 970 to 1040 and finish turn up pop up reinstall hotfix.., installed from built 1086 to 1112 finish turn up pop up and latest built 1114 turn up pop up (attach screenshot), What is normally?...
Thanks,..
Sorry for My English
End
EDDY wrote:
Thanks...,
When you use File\Save as... in the appearing Dialog, select PLN as file type, there is an Options button. If you click it, you have the choice to set Compression ON. This wil ldramatically reduce file size. If you already have Compression ON and your file size is still 218 MB, then it must be a huge file, which must have huge amounts of data and elements in it.
