Problem: "cannot find pict file" ????
Achille Pavlidis
hi everybody... i'm experiencing this strange problem... i'm running AC9 with OSX 10.3.9
every time i open a specific document, i get a series of warnings, that say: cannot find pict file "xyz" called at line "xyz" of the file master_gdl.
This also happens every time a make a 3d view. I noticed this started once i installed Archiglazing, and made a few objects with it. I do not get any missing textures in the library manager, and cannot find those files.
Anyone has a clue???
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
Djordje
You are using Studio Arkada libraries, right? Load them fully; they have textures hard coded in the Master_gdls.
Then it will go away ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Achille Pavlidis
yes Djordje i'm using the Arkada lib...(you must have quite an experience!) some old version before AC8... the funny thing is those warnings appeared when i had them fully loaded... now that i have loaded only some folders of the library the problem is solved.... thank you
