We value your input!
Problem with SEO and Floor Plan Cut Plane
CarlM
I have problems with walls "cut" with SEO where the roof acts as the operator elements. However in plan view the walls that are below the roof AND below the Floor Plan Cut Plane still shows. I am sure I am missing something very simple but I can't figure out what I am doing wrong.
Cheers!
AC 27 SWE, 64-bit
Windows 10 PRO
HP ZBook Fury 16 G9 Mobile Workstation, i9-12950HX, Nvidia RTX A4500, 64GB ram
4 REPLIES 4
CarlM
Here is the section showing the level of the Floor Plan Cut Plane level...
AC 27 SWE, 64-bit
Windows 10 PRO
Seo operations don't show on floor plan. You can trim your wall with you roof and this operation does show on floor plan. Sorry for my english
If you give your roof cover fill a non-transparent background (white pen 19 or 91 in standard pen sets) it will obscure the walls below.
CarlM
Thanks - this solved the problem!
AC 27 SWE, 64-bit
Windows 10 PRO
