Problem with visibility? Important, please help.
Hello, I have big problem becasue in Thuesday I must give my project to professor to pass subject in school.
I almost done everything and wanted to print plans to pdf files and something go wrong. I don't see doors, windows, some walls or see walls from different floors... I don't know whats happend but before when I saw this problem I made something with layers - maybe that's the reason? I tried to change layers group but that's not working. I'm not very good in ArchiCad, still learning. I think that can't be very big problem for some of you so please help me, it's very important.
I'm sending to you attachments how it look.
5 Replies 5
check floor plans cut plane. in Document menu.
vistasp
Mentor
And if that doesn't work, try your Model View Options.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
When you post pictures here load them up to Graphisoft and not link to a site like that again. I go out of my way to avoid sites like that.
Please delete those links and upload the pics here.
Make sure your Renovation filter is set for 'Planned Status'
If by a long shot, none of the previous posts fix it,
you could maybe have a story set to something like 0' or a very small height.
