Problems Exporting a Sketchup File Into Archicad
I'm currently having a few problems exporting a sketchup model into archicad to create a roof structure i thought was impossible to achieve using Archicad alone.
So i created these roof structures of varying height and complexity with the intention of simply exporting into Archicad using the sketchup export add-on i have installed.
Yet when i attempt to export the file into Archicad i get absoloutely nothing..not even an error message saying it had failed...just a blank plan and nothing in 3d.
I have attached a screenshot of the roofs created in sketchup ready for export. If anyone can suggest any way of overcoming this problem i'd be extremely grateful
Thanks alot,
James
P.S Im using AC12 on a computer with dual core processor - 3GB RAM and 145GB Hard Drive
12 Replies 12
What version of SketchUP are you using?
PeterKis wrote:
- The current SketchUP add-on supports .skp file format up to v6. When you exchange data with the SketchUP application, please be sure that the appropriate file format is used.
ah...i think im using Sketchup 7 at work where im attempting to do the export...i've just tryed to export another file using V6 at home and its worked fine...so ill give that a try tomorrow!
Thanks very much for your help
vfrontiers
Loosely related:
I believe I saw one of the tutorials showing that objects from GOOGLE WAREHOUSE can be DROPPED right into ArchiCAD.... Is this TRUE? I don't recall it explaining the methodology...
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
Erika Epstein
After installing the plugin:
File>Google Earth Connections>Import Model from 3D Warehouse.
Works a treat!
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
vfrontiers
Are you freakin kidding me! Another NOT AVAILABLE for MACINTOSH crap...
Ugh... I quit...
Duane
Visual Frontiers
AC3.14 - AC29
Yes, a frustration for Mac users with no timeline for a fix, as the problem relates to software issues between the Google programming interface (API) and the methodologies used by ArchiCAD to date.
One workaround if you have a SketchUp Pro license is to save things out of SketchUp as 3DS and use the 3DS importer in ArchiCAD.
That just brings up a separate annoyance with Google (continuing the exact policies of @Last, who they acquired): a SketchUp Pro license is only for one platform - Mac or Windows. You have to pay for the other platform, or go through hoops to switch platforms. Not unlike Adobe. All of these guys let you install software on one desktop and one portable computer - but will not provide licenses that let your portable be a different OS. Stinks. Definitely a nice thing about ArchiCAD (with dongle) and Artlantis (with internet activation).
Dennis Lee
Ugh... I quit...
I wonder if this is a result of a bigger fight going on....Google vs Apple ?
They are competing in the smart phone business for sure and probably many more, and it's quite possible that things are not that friendly between the two giants... and maybe Graphisoft is just an innocent (powerless) bystander in this. Just some speculating...
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Eduardo Rolon
Google's CEO? Eric Schmidt is on Apple's Board therefore that might be a very strange war.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
owen
Sorry I can't help with the problem .. but my understanding was the SketchUp conversion process would convert everything to 3 ArchiCAD elements - Slabs, Walls and Roofs. For ArchiCAD to import the SketchUp model it has to be something AC is capable of modeling with those tools - so it is possible to model it in ArchiCAD, just maybe not as quickly as SketchUp.
Personally i always found the SketchUp import to be a bit of a mess (99.9 degree roofs stretching to infinity, etc) .. but it has been a long time since i tried it out so maybe it has improved.
cheers,
Owen Sharp
Design Technology Manager
fjmt | francis-jones morehen thorp
iMac 27" i7 2.93Ghz | 32GB RAM | OS 10.10 | Since AC5
