2009-03-23
06:39 PM
2023-05-23
03:04 PM
Rubia Torres
2009-03-23 07:11 PM
peach49 wrote:What version of SketchUP are you using?
Yet when i attempt to export the file into Archicad i get absoloutely nothing..not even an error message saying it had failed...just a blank plan and nothing in 3d.
PeterKis wrote:
- The current SketchUP add-on supports .skp file format up to v6. When you exchange data with the SketchUP application, please be sure that the appropriate file format is used.
2009-03-24 09:45 AM
2009-03-25 11:29 AM
2009-03-25 05:08 PM
2009-03-25 08:40 PM
2009-03-25 09:02 PM
2009-03-25 10:16 PM
vfrontiers wrote:I wonder if this is a result of a bigger fight going on....Google vs Apple ?
Are you freakin kidding me! Another NOT AVAILABLE for MACINTOSH crap...
Ugh... I quit...
2009-03-25 11:40 PM
2009-03-26 01:53 AM
peach49 wrote:Sorry I can't help with the problem .. but my understanding was the SketchUp conversion process would convert everything to 3 ArchiCAD elements - Slabs, Walls and Roofs. For ArchiCAD to import the SketchUp model it has to be something AC is capable of modeling with those tools - so it
I'm currently having a few problems exporting a sketchup model into archicad to create a roof structure i thought was impossible to achieve using Archicad alone.
So i created these roof structures of varying height and complexity with the intention of simply exporting into Archicad using the sketchup export add-on i have installed.
