Problems viewing plan in 3D - Memory Full
Our archiCAD file is 190mb - whenever we try to view in 3D it fails saying that memory is full. We have used the polycount tool and changed all objects to Simple. We have also turned the objects off in the "elements to be shown in 3D". Does anyone have any other ideas as to how we can get our file to view in 3D? All advice is appreciated!
4 Replies 4
TomWaltz
What are your machine specs? What verson of Archicad are you on?
Tom Waltz
I have been getting this same problem lately. The 3D window starts generating in OpenGL and almost gets done when I get a message that there is an error in the OpenGL add-on and something like it is out of memory and it will not finish. If I use Archicad 3D it is OK. My file size is about 70 MB or so. I would also appreciate any ideas on this.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
We are using ArchiCAD 9
Computer Specs:
3.2ghz processor - Windows XP
2.0 gig RAM
256mb video card
Djordje
Try the old method of marqeeing with the fat marquee the portion of the project that you want to see.
This error usually happens because of a too detailed lib part, or a slab or a mesh with contours or holes curving unto themselves.
It might be your video card, too - check the drivers.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
