‎2008-11-26 08:51 PM
‎2008-11-27 02:42 PM
Daniel wrote:Might be a graphics card driver issue. Just guessing.
Just started using curtain wall tool and notice some buggy behavior. Firstly, at some point while editing the curtainwall in 3d, I lose my constraining (shift key) when I get back to plan. I have to quit ArchiCAD to get it back again. VERY ANNOYING.
Secondly, when editing curtainwall, I cannot move frame/mullion members in plan. Isn't this sort of essential ??? Am I missing an edit mode or something? It seems I can only edit in 3d. Which requires that I create 3d proxy elements in order to snpo mullions into an accurate spot. Additionally, when doing this method, the curtainwall obscures foreground objects that I want to snap too. Also seems like a bug.Yes, editing Curtain Walls is only possible in 3D.
Thirdly, when I have my curtain wall laid out and I want to edit the vertical spacing via the System Settings, the curtain wall reverts back to the orginal (incorrect) layout, forcing me to suffer through the issues mentioned above.If you select the Curtain Wall in the Floor Plan Viewpoint, go to its settings Dialog and change the Scheme in the Scheme page, that should change the Scheme.
Perhaps I am jumping the gun on some of these problems and missing a better workflow. Please let me know if anyone has a better way of working with the curtain wall tool.
‎2008-11-27 03:17 PM
laszlonagy wrote:have the same issue.... butDaniel wrote:Might be a graphics card driver issue. Just guessing.
‎2008-11-27 06:20 PM
laszlonagy wrote:To clarify, my situation might be this: I have placed a complicated curtain wall that required some manual positioning of the vertical elements. I later find out that we need to add a row of operable "smoke windows in the curtain wall system.
However, if you click the System Settings button in the small command menu appearing in the upper left corner of the 3D Window while editing the Curtain Wall, any change you make there will be immediately applied to the Curtain Wall (since in that case the program knows that there is one Curtain Wall opened for editing and that is that one to which changes need to be applied).
So it is a bit tricky.
‎2008-11-28 11:45 AM
‎2008-11-28 12:50 PM
Daniel wrote:can't help with the scheme settings and customisation issue, sorry, but i know what you mean about the shift constraint...laszlonagy wrote:
Xristina - This is where my shift constrain problem bites me. I have to use it in 3d in order to get the correct column layout. So when I go back to plan, I have lost the ability to shift constrain and MUST quit ArchiCAD to get it back. I am in a teamwork file too, so this is an extra cumbersome "feature" of the curtain wall tool.
‎2008-11-28 06:19 PM
‎2008-11-29 05:23 PM
‎2008-11-30 04:46 AM
laszlonagy wrote:Agreed.
I am sure GS will continue to improve the Curtain Wall Tool.
Although it does not know everything, for a first iteration I found it pretty impressive.
‎2017-12-06 04:59 PM
