Problems with cutting building materials
When I extend the compound wall on the floor composite materials do not fit forming a clean cut, as in the presentation videos of ArchiCAD 17. Is there any setting that must be enabled before work?
3 Replies 3
The configuration screen of building materials there is a restriction message. What do I do?
Eduardo Rolon
Check your project preferences.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Fantastic. Thank you. It worked
