griggadee
Problems with editing text? An old but unanswered thread...
Just spotted this thread whilst looking for an answer to the same problem and noticed that the solution I found wasn't stated on the original thread which has now been closed / locked:
http://archicad-talk.graphisoft.com/viewtopic.php?t=25988&sid=3ffe8634ca02d02c10a809e511d9c2e6
I couldn't figure out why all of a sudden I wasn't able to edit text by double clicking on it. I finally figured out that I didn't have the quick selection box ticked which instantly solved the problem. This solution wasn't given on the original thread so I thought I would post it again in case anyone is having a similar problem and looking for a simple fix. See attached JPEG for info.
Paul
Paul Griggs BSc (Hons) MCIAT MCIOB
Chartered Architectural Technologist
AC23, i5 3570K Processor, 16gb RAM, NVidia 570GTX Graphics Card, 250gb SSD Drive
3 Replies 3
God bless you !!!
And remember you can use the space bar to temporarily toggle the quick select on if is off and off it it is on.
Personally I like to leave it off and just space bar when I need it.
This is of course if you have the select (arrow) tool active.
If you are in any other tool just SHIFT + SPACE BAR.
Bob Moore
Thanks.
AC 7 - 29
iMac 27"
Mac OS Sonoma 14.0
3.1 GHz 6-Core Intel Core
32 GB 2667 MHz DDR4
Radeon Pro 575X 4 GB
