Problems with mesh...
Hello, problem is that the landscape shape which I am drawing in archiCad10 with mesh is very complicated and when I add more shapes and lines to mesh(with magic wand) it is creating many points and then after adding few lines it does not let me to add more, so that I can't finish drawing my shape
I wanted to know if it is possible to create mesh and add lines to shape so that it did not create many points, or if it is possible to erase points, or maybe there is other way to do it....
Thank you for your help
Thomas Holm
As usual...
http://www.archicadwiki.com/TechNotes/Handle_huge_surveyors%27_drawings?highlight=%28TechNotes/%29%7...
There are a lot of tips in there - use the ones that apply!
You could always do a search in this forum before you ask
I did search, but probably was not looking there where I should.
Thank you very much for your help
