Problems with wall intersection
stefanonodari
Hi guys,
I have some problems with the intersection of three different wall (with three different thickness).
The all walls have the same two material: an internal material and a plaster skin.
There is always a triangle in the angle.
All the walls line connect correctly.
I just try to modify the number of junction order but I don't have any resolution...
I attach below a screen of the case:
7 REPLIES 7
These are not quite the same walls as yours but they all have the same building materials in the composites and all have the same junction order.
As you can see they trim fine.
Where are your reference lines? - mine all join at the same point.
Also are there any other walls - maybe in a hidden layer?
They can interfere with the trimming.
stefanonodari
I’d like to view a T shape connection for internal material without trim or triangle...
David Shorter
Check that all your reference lines meet correctly like this
failing that attached a module file of the junction
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
stefanonodari
Yes, three walls are well connected all together.
Maybe it’s a problem of the version of Archicad that I’m using, it’s 22.
In your drawing it’s fine, which version are you using?
David Shorter
24 but tried it in 22 and works fine, must be something on hidden layer affecting the display
Mac Studio
iPad Pro
iPhone
stefanonodari
This is an image of reference line's connection
David Maudlin
stefanonodari:
Try selecting each wall individually and changing its Junction Order up or down.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
