stefanonodari
Projection of straight wall with angle wall
Hi, I have two connected walls:
- 1 straight wall
- 1 angle wall
The section plane is higher than wall, so I don't see the section but I see the projection.
I attached floor plan and a 3d view.
In the plan I select in red the line that missed in the plan and in yellow the line that I want to hide.
3 Replies 3
Hello stefanonodari,
To adjust the intersection of elements (or their skins/components) you can change Building Material Priority :
https://helpcenter.graphisoft.com/user-guide/88751/
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
It looks like a bug to me. I could easily reproduce it in Archicad 24.
I will report it to Graphisoft.
Unfortunately, I cannot recommend any good workaround besides drawing above the walls with a Fill to achieve the desired 2D representation.
stefanonodari
ok, thank you LaszloNagy
