Production issues on a subdivision
tsturm
Does anyone have any suggestions on how to handle a subdivision project?
We are working on a project which has 12 houses. For the most part they are all the same. The problem is the differences of plans and elevations. All the homes will use the same details, same window/door schedules and wall sections.
Where we are having some dispute in the office is how to set up the production of the project. Some are talking about a PLN for every house. Some want to use a file to hold the common details and use holders to reference those common details. And some want to use modules of each house into a central file which has all the common details in it. The problem lies in using the Auto Label of drawings in Plotmaker. If we just hand wrote in the drawing, I am sure this would all not be a problem.
I have the site plan all worked out using hotlinked drawings. I just cannot figure out the best way to work on all the houses and the differences between them.
anyone have any suggestions on this model type?
Terrence Sturm, Architect
_______________
MBP OSX 10.15.4 Quad Core Intel i7 2.2hz
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
11 REPLIES 11
TomWaltz
K&A does this all the time.
The general approach is:
1) a PLN with all unit types and common details in it. Each story of the PLN matches one story of a Unit. These are published to .MOD files to allow for a stripped-down version of each unit (sans dimensions and notes) to be placed into the buildings. Anything and everything that repeats goes into this file.
2) a PLN for each building, to generate elevations and sections
3) a single LBK
As for the detail linking, we just enter the text manually as late in the project as possible. I've seen some people get around it with a general note "See Sht A12 for details" or something like that on their sections. It's cheating, but it works.
I can only imagine the performance issues of linking every house into one PLN....
Tom Waltz
tsturm
Tom
I have done this type of referencing in an apartment complex. But we are doing a housing complex of 12 separate duplexes. The Units are joined in different fashions so that the roofs and elevations are unigue in every case.
what I am hearing is do the details in a separate file. Use detail keys that are manually typed in. Do not rely on Plotmaker to do the numbering for you.
anyone else with a recommendation?
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
TomWaltz
tsturm wrote:
Tom
Most of the projects were duplexes or flat/townhouse combinations.
The details are not really in a separate file. They are in the same file as the units.
Like I said, anything that repeats goes in with the units. That may mean that that MODs only contain the interiors of the units and a couple exterior walls with windows or porches.
I've seen some jobs that had a separate porch module, others that had only interiors in the modules because the connections and variations were so odd.
To handle some variations, you can use Layer Combinations of different exterior walls to make multiple exterior conditions with the same interior. Since they are publishing to MOD, each MOD ends up with different content.
Tom Waltz
tsturm
If the details are not in a separate file, then how do you handle getting them into each PLN file for the production set?
If you are copying them in, then what happens to the links for the detail windows? Do you then just use the detail marker to mark the locations and there is no true detail cut anywhere? I suppose that once you figure it out then there would be no need to have the actual model location to work again from.
When you are using MODs, are you really saving them out as .MOD files or just using the attach drawing feature like a XREF?
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
TomWaltz
They are never copied into each PLN. They are just placed into the LBK.
Since the company does so many of this type of projects, very few new details are cut from the model. Most are from the office detail library
The units, with their appropriate layer combinations, are saved as View Sets and published to MOD en masse. Like I said before, this allows you to make several exterior layers that all wrap around the same interior. You can also dimension, note, and cut interior elevations from the original units and just turn those layers off before you publish to MOD.
Tom Waltz
Rick Thompson
One consideration is if you are trying to pull material takeoffs. What you describe is pretty much all I do. I started having a base file and different elevation treatments with layer combinations. It worked, but I soon realized how much harder it was keeping things straight, and forget material list. I fully develop the base model (fully, which is not really reality) and duplicate the file and modify it for exterior variations.. as well as a basement version. That too is hard with layers, but possible... just too much confusion and with inherent weaknesses. You can copy/paste to update pretty easily.
I have one file I keep all details in, including sheet notes and title blocks. This makes updating and in ac10 much easier. In ac10 you simply have that detail file available and drag those details off onto the sheet in the open project file. I work with small houses, so the set is small enough I don't worry about detail numbers. I generally place foundation details on the foundation sheet.. etc, so that's a mute issue for me.
I would definitely recommend one pln per house plan. Not for your sake (but I feel it is the cleanest and least confusing solution for you too), but for the contractors. This should help considerably with printing and navigation for the poor people using the plans. If you do too much combining, then the person distributing the prints will split it up anyway and that's a quick path to confusion. And then there is the permitting, and revisions based on their individual whims.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
tsturm
This explains why you do not copy the details into the project PLN and you have to hand type the detail numbers. Your details are coming from a central location outside of the projects. A Office Detail Library.
Could you draw a diagram of the process to show how you are using the different exteriors with the different interiors and where everything lines back up to create building sections and exterior elevations.
I get the sense your projects are broken up into Shells and Interiors. Then you are just putting different interiors into different shells.
Our company does enough differnt work that we have not set up a central detail library. Our details tend to travel with the projects. However, in the case of this project, we are looking to use that type of system due to the number of buildings to use the same details.
I am just trying to find a way to make the coordination of the standard details more automated for each house.
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
TomWaltz
Nope. It's just a really good "unit" template that is pre-stocked with details. It's all in the same PLN as the Unit Plans are.
There is no "interior/exterior" division. There are either
(1) MODs placed for the parts that are typical, which are usually a combination of interior and exterior
(2) elements like roofs and foundatons that are not typical and are drawn/modeled "in place" in each house
Tom Waltz
tsturm
So the details in this Master PLN are all linked to the drawings, but none are actually cuts of the model, correct?
What type of system, I will ask, do you use to organize all these details? How do you pull from this master list for the details you really want to use? How are the actual detail windows labeled as this label can be changed once set in a view set. I have been trying different systems of numbering as I have found that each detail window needs a unique number. Names can be the same.
Do you MOD in the Houses to this Master PLN? Still not grasping how you are dealing with the exterior versus interior and the upgrade options on the houses. I think I get the part about options like porches, patios as additional MOD to the base house. But how about the House itself. Are you using different plans with the same shell?
_______________
AC 17 build 5019
AC 22 build 7000
AC 23 build
AC 24 build 5000
