Profile arc resolution problem
Hi guys,
I made a profile as in the picture, but when I used it and drew a beam using this profile, it looked different - arcs are not arcs but straight lines.
What am I doing wrong ?
thanks!
David Maudlin
kielbasa:
It is a known issue, discussed here: Custom Profile.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank You David, that helped me a lot...
My apologies for duplicating the question.
Steve Jepson
notice that with the molding library parts you can set the resolution to 999 or what ever to make the curves of the molding a smooth as possible.
If you make your molding into a library part you could add a RESOL script like the one in the Molding Straight 21 and Molding Curved 21 have. I don't know exactly how to do that but it should be possible to get smoother curves by using some GDL scripting.
no reason to settle for less than super-smooth curves in ArchiCAD.
