Profile manager element update
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2010-10-13 10:19 PM
thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 02:03 AM
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 07:55 AM
ejrolon wrote:The profiles do update after editing though a rebuild may be necessary in 3D if it is active at the time (I don't remember for sure).
AFAIK complex profiles do not auto update you have to reapply the changed profile or I am missing something with your problem.
I'm not sure I understand your problem either Tom. Are you creating a profile, placing an instance then changing and storing the profile?
Any change to an existing profile should update all existing instances, except for individual dimensional/stretch adjustments.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 02:41 PM
In V14, it appears I have to select all the original profiles while the editor is open, then "apply to selection". This can be a problem if the profile occurs on various stories.
I did notice that some of the original profiles changed to "custom" when selected on plan, rather than the name originally given. Don't know how that happened but would seem to be the root of the problem; if the names don't match, the profile obviously would not update. I wonder if it's a migration issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 04:00 PM
Change all your custom profiles back to named profiles. Then updating should work fine. And don't use 'apply to selection' unless you want a one-off, non-linked wall/beam/column with a custom profile.
Hope that makes sense.
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 07:34 PM
Thanks for the heads up.
Tom
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 08:33 PM
I thought it was one of those 80% implemented features
AC28 US/INT -> AC08
another Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 10:11 PM
I think in my coworker's case, she was selecting the custom profiles on the plan, then selecting the profile in the profile manager, updating, saving the profile, than clicking apply to selection. It was something super subtle and until I made her go through her standard procedure, saying everything out loud while I watched we couldn't figure out why it was happening to her.
Basically a bad habit she picked up elsewhere in AC that usually doesn't cause a problem, but did here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-14 11:04 PM
Tom.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2010-10-15 01:11 AM
If only we could replace ourselves with robots, then BIM would finally arrive.
