‎2010-03-08 03:58 PM
‎2010-03-08 04:33 PM
‎2010-03-08 06:27 PM
‎2010-03-08 07:09 PM
Erika wrote:If it is simple scaling it's fairly easy to script with the SWEEP function. (This could also be done with a PYRAMID and a CUTPLANE.) For a changing profile a series of RULED elements would do the trick.
Open the library part and change the status code.
It might be simpler to create a fill in the shape of the section, drag this into the 2D window and from their copy it into the 3D window changing the poly_ to a prism of some type.
DNC goes through this in his cookbook pg. 1.46.
Alternatively you can capture the section as a custom profile and then apply it beam, wall or column tool as appropriate.
HTH
‎2010-03-08 08:29 PM
‎2010-03-08 09:27 PM
‎2010-03-08 09:31 PM
‎2010-03-08 09:47 PM
‎2010-03-08 10:05 PM
‎2010-03-08 11:50 PM
Krippahl wrote:You
I looked at Cad Garage and Encina tools, and it looks like they are not able to do this.
