‎2006-08-01 03:42 PM
‎2006-08-01 04:15 PM
Michele wrote:Try this.
I can't get the list of my drawings to show up in the order that I need them to show for our cover sheet.
It also still shows a sheet I told it not to look at.
It would be fabulous if it could show automatically the sheets used for our sheet index.The way to control what layouts are listed is the Criteria section. You can list members of subsets (best IMO), layouts with given masters (eh), and/or which layouts were published in a given publication (Combine this with the subset criterion to not list non-published layouts).
‎2006-08-01 11:45 PM
‎2006-08-02 08:45 PM
‎2006-08-03 08:03 PM
‎2006-08-03 09:26 PM
Michele wrote:Apparently (from my recent experience) the "is not" filtering criteria does not work. I, too, had to specify the items I WANT to list.
I found out in the criteria section you have to list all the subsets you WANT to list. Which of course is the longer way of doing it!!!???? I can just list the ones I don't want to list.
‎2006-08-03 11:18 PM
‎2006-08-04 12:18 AM
‎2006-11-14 12:29 PM
Matthew wrote:I am still on Archicad 9.0...Is there a way to make a project index list using Plotmaker 9.0?
We use the automatic drawing list for the in-house sheets and either a text block or linked PDF for the consultants. The lists are typically separate columns on the cover so the formating isn't much of a problem, and the consultant's sheet index has to be maintained manually anyway so I don't see that much advantage to including it in the automatic system.
‎2006-11-14 12:36 PM
