For the purposes of creating multiple views using different height cut planes, I need to use either projected or projected with overhead doors. In the attached image, those doors appear in the closed position when used in either projected with overhead or cut only walls. They are all set to be in the 90 degree position, so something is not working as expected. Can someone please confirm that there is an issue with these doors not displaying correctly?
Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
