2017-11-21 08:37 PM - last edited on 2023-05-24 08:26 AM by Rubia Torres
2017-11-21 09:46 PM
methy wrote:I can't answer the first question, but I have spent some time trying to wrap my head around around the Classification/Properties scheme. The Classifications are like the "high level" pigeonholes, which allow a wall to be an interior wall, an exterior wall, millwork, or a piece of art. Specific properties can be assigned to that specific classification pigeonhole depending on what it is, so you don't have to see all properties -- all the time. A wall which is an exterior wall is likely to have only a certain set of relevant properties, whereas a wall which is functioning as a crown molding (and has that set as its classification) can have completely different ones.
Also im not sure why we have the classification manager and also the property manager do they not both do a similar job to one another?
2017-11-22 09:49 AM
methy wrote:On migrated files newer stuff will be missing.
im not sure if it is simply because my archicad template file was originally a v19 file or..?
